Hello again,
The DTC'a are for an open or short circuit to battery V+ or a short to ground on the wheel speed sensor. DTC P1145 is for RHS and DTC P1155 is for the LHS. These DTC's are also for the ABS Modules, but the DTC malfunction is again for an open, short circuit to battery V+, or a short circuit to ground on the wheel speed sensor. I have included in the diagrams below Pin Point tests that will track down where the fault is in your vehicle. It is straight forward and simple. The issue may be in the connector or associated wiring to the module, and not in the module itself. They also do not require any special tools to do them. Please go through these pinpoint guides and let us know what you find out.
Thanks,
Alex
2CarPros
Images (Click to enlarge)
Feb 23, 2019 at 8:19 PM
