ABS light on
117,673 MILES • 6 CYL • 4WD • AUTOMATIC
PRETTY LADY
  • 6 POSTS
What could be the reason why my ABS light is on? I had three different things come up. Speed sensor, module and ABS pump. I am confused. Do I have to go to the dealer to find out why it is on?
Jul 13, 2017 at 6:11 PM
  • 55,721 POSTS
It sounds like you have a module that is out Here is a guide that will give you an idea on what you will need to do to replace it, they have them on Amazon, $190.00. Here is the guide:
https://www.2carpros.com/articles/how-to-replace-a-abs-controller
Feb 27, 2021 at 5:37 AM
PRETTY LADY
  • 6 POSTS
Thank u. Are they new or used on amazon
PRETTY LADY
  • 6 POSTS
What if it is my abs pump then what do I do then
  • 55,721 POSTS
They are new on Amazon, the pumps don't go out that often on these cars
Cheers, Ken
PRETTY LADY
  • 6 POSTS
OK but when I got the code it came up c0110 if I remember correctly. And that was for the pump so what should I do
  • 55,721 POSTS
Yep that is a pump code,
Here are some diagrams to help you get it changed out.
Make sure you use a line wrench
https://youtu.be/HNlvgp_YfQ0
Cheers, Ken
PRETTY LADY
  • 6 POSTS
Do I have to get it programmed by the dealer
  • 55,721 POSTS
Some you do others you don't. Do you have regular size tires on the car then you should be okay.
Please let me know though,
Best, Ken
