ABS light is on. Possible replacement for the module
105,550 MILES • 7.7L • 4 CYL • FWD • AUTOMATIC
MATTCHONG
The ABS light is on, along with the BAS and ESP. I took it to a mechanic and said it needs a new ABS module. I been looking online for an ABS module for the A160 but no luck. I'm going to check to see it have to do with any of the valves or wiring into the module. I would like to see a picture of the ABS module and a schematic of it. Also if you have a link to a seller for the module, just in case. Any suggestions or ideas will help too.
May 12, 2015 at 3:05 AM
  • 31,937 POSTS
I would be getting a second opinion from a dealer, ABS modules rarely fail ( I am not saying that this is not the case here) I would like to know the codes set and I do recommend a second opinion as I am sure that you would not want to spend some thousands doing this to find it was not the problem in the first place.
May 13, 2015 at 8:30 PM
