ABS light turned on
70,000 MILES
ALIREZA619
My ABS light came on and the code on screen was right ABS sensor which I changed. The light went off but after 20 minutes of driving, light come up again . Any idea what is the problem?
Jun 28, 2020 at 12:30 PM
  • 110,248 POSTS
Was it for the same sensor? Also, what specific code was it? Was the wiring properly routed and not damaged? Let me know so I can do a little research.
Jun 28, 2020 at 3:38 PM
ALIREZA619
Thanks a lot for prompt answer. The code was 5101 and the connection looks well. I have a plan to do some diagnostic on new sensor, but I have problem removing old sensor and insertion of new sensor as well. Is there a possibility of overheating brake system to damage sensor?
Jun 29, 2020 at 4:15 AM
ALIREZA619
And yes was the same sensor and initially work and light turns off but it came on again after 20-30 minutes of driving!
Jun 29, 2020 at 4:16 AM
