ABS Light and Traction Control Light on Dash?
75,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
OREO101
  • 103 POSTS
These lights just came on today. Can one use some kind of tester to pinpoint the cause? Possible Speed Sensor? Thank you for all your incredible help in the past!
Greg
Feb 6, 2025 at 12:07 PM
CARDOCTOR74
  • 62 POSTS
Hi , yes you can have it scanned with an obd2 scanner that reads the abs system as well. Most local auto parts stores will scan it for free. Once you have the code, I can help you determine the fault and repair. It may just be a faulty sensor.
Feb 6, 2025 at 9:57 PM
OREO101
  • 103 POSTS
Okay!
Feb 7, 2025 at 2:51 AM
CARDOCTOR74
  • 62 POSTS
Very glad to help. Thanks for using.
https://www.2carpros.com/questions/abs-light-and-traction-control-light-on-dash
If you found this helpful, I would not object to a tip lol. I’m here if you need me.
https://venmo.com/u/hondaguygold
Feb 7, 2025 at 2:58 AM
OREO101
  • 103 POSTS
I just ordered a Autel Brand scanner.
Will follow up!
Feb 10, 2025 at 1:41 PM
  • 55,748 POSTS
CARDOCTOR74 just joined the team! Please let us know when you can.
Feb 12, 2025 at 1:07 AM
OREO101
  • 103 POSTS
Got new ABS tester.
Shows C1206 RR Speed Sensor issue.
Replaced sensor but cannot clear lights.
And now have another light which shows up as "Brake" with a ! And P above it.
See pictures.
Feb 26, 2025 at 6:44 AM
OREO101
  • 103 POSTS
Why do you think I cannot clear these lights?
I now have 5 darn lights.
My Foxwell NT630 Pro is supposed to be able to clear these.
What about disconnecting battery for so many minutes, how many minutes?
Help!
Feb 26, 2025 at 1:05 PM
  • 55,748 POSTS
The second code is the issue, C1211, you have an ABS control module that needs to be replaced which is common. Here is the location and how to replace it. Clear the codes once completed. Check out the images (below). Let us know how it goes.
Feb 27, 2025 at 3:03 AM
