ABS light and brake light pinout needed?
116,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
DANIEL KELLER
  • 7 POSTS
Looking for a pin out for the ABS connector to check power and ground.
Year:2008
Make:Ford
Model:F-150
VIN:1FTRX14W38FA51587
Odometer:116680 miles
Vehicle Software Version:V50.35
The following systems is abnormal:
ABS (Anti-Lock Braking System)
DTC (2)
1.B1596-E0 Service Continuous Memory DTCs Continuous Memory DTCs
2.B1342-E0 ECU (Electronic Control Unit) Internal Error Continuous Memory DTCs
Apr 6, 2025 at 2:48 AM
  • 110,248 POSTS
If you look below, I attached the wiring schematic as well as the connector pinout. When you check things, make sure there isn't a cracked connector pin. I chased a similar issue for way too long. LOL
I hope this helps.
See pics below. Note, I had to cut the schematic in two, so it was readable. I did overlap the two so you can follow from one to the next.
Apr 6, 2025 at 7:22 AM
DANIEL KELLER
  • 7 POSTS
Sorry for the slow reply but I only get weekends to work on this truck. Got 2 ohms resistance on the grounds and good voltage at the power supply and pin 32 with key in run. Any other test I can use to prove the ABS module is bad before I replace it.
Apr 11, 2025 at 11:48 PM
  • 55,721 POSTS
Not really, if you have power and ground but the ABS is not working with these codes or you have codes then it needs to be replaced.
Apr 14, 2025 at 2:15 AM
DANIEL KELLER
  • 7 POSTS
ABS module replaced. All is good. Thanks for the help.
Apr 29, 2025 at 1:47 AM
  • 55,721 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Apr 29, 2025 at 3:46 AM
