ABS light turned on
132,633 MILES • 2.7L • V6 • 2WD • AUTOMATIC
PETERH19
ABS signal light is on.
Jun 4, 2019 at 4:14 PM
PETERH19
What is the fastest way to fix this?
Jun 4, 2019 at 4:20 PM
Good morning,
There is a fault stored in the module for the failure.
You need to have that code read in order for us to help. A parts store will read it for free for you.
There are sensors that are common failures but need the code to get the flow chart to confirm.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Jun 4, 2019 at 8:41 PM
