Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Magnum
Warning Lights
ABS Light
ABS light turned on
2008 DODGE MAGNUM
132,633 MILES • 2.7L • V6 • 2WD • AUTOMATIC
PETERH19
MEMBER
ABS signal light is on.
Jun 4, 2019 at 4:14 PM
PETERH19
MEMBER
What is the fastest way to fix this?
Jun 4, 2019 at 4:20 PM
Experienced Mechanic
Good morning,
There is a fault stored in the module for the failure.
You need to have that code read in order for us to help. A parts store will read it for free for you.
There are sensors that are common failures but need the code to get the flow chart to confirm.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Jun 4, 2019 at 8:41 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
