ABS lights are on after battery drain?
213,000 MILES • 4 CYL • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
Battery drained because i forgot a light on. Jumped it and now its running fine but traction and ABS lights are on.
Sep 12, 2025 at 9:03 AM
  • 55,721 POSTS
So you have codes: So I would replace the left front wheel speed sensor, then use your scanner and clear the codes. The first to codes are because the battery was low.
6111 - VSA/ABS modulator control unit power source (IG) low voltage
8311 - PCM (Powertrain Control Module) malfunction / VSA stoppage due to a fault in PGM-FI or engine control
2311 - front left wheel sensor issues
. Please let us know what happens.
Sep 14, 2025 at 4:26 AM
