ABS light
165,000 MILES • V8 • AWD • AUTOMATIC
JEEPAZ
I disconnected the battery for over twenty four hours while I worked on the A/C. now that it is all back together the ABS yellow light will not go out. the ECU, sensors, brake fluid and master cylinder checks out okay. how do i clear the default?
Aug 7, 2017 at 9:10 AM
CARADIODOC
  • 34,415 POSTS
Most ABS codes from that era need to be erased with a scanner. You can erase engine and transmission codes by disconnecting the battery momentarily, but that usually doesn't work with ABS Computers and some Air Bag Computers.
Aug 8, 2017 at 10:42 PM
