ABS light
JEEPAZ
  • 1995 JEEP GRAND CHEROKEE
  • V8
  • AWD
  • 165,000 MILES
I disconnected the battery for over twenty four hours while I worked on the A/C. Now that it is all back together the ABS yellow light will not go out. The ECU, sensors, brake fluid and master cylinder checks out okay. How do I clear the default?
Monday, August 7th, 2017 AT 4:10 PM
CARADIODOC
  • 33,916 POSTS
Most ABS codes from that era need to be erased with a scanner. You can erase engine and transmission codes by disconnecting the battery momentarily, but that usually doesn't work with ABS Computers and some Air Bag Computers.
Wednesday, August 9th, 2017 AT 5:42 AM
