Engine not starting
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
LEX215
It came on and car did not wanted to start. then I waited, then crank it the second time nothing happened. then on the third crank came on. I would like to know what is the problem? ABS light on Thank you
Oct 31, 2017 at 3:48 AM
  • 110,248 POSTS
The ABS should not have anything to do with starting. I would recommend having the computer scanned to determine if there are any trouble codes and what they are. Start there. The ABS light usually results from a bad connection or sensor at one of the wheels.
Oct 31, 2017 at 12:23 PM
LEX215
Okay, thanks.
Oct 31, 2017 at 4:57 PM
  • 55,721 POSTS
Now when you say crank and start does the engine not crank over or crank over and not start?
Cheers, Ken
Nov 2, 2017 at 4:28 AM
LEX215
Cranks over not start. but, now it is working fine. I do not know what is the problem cut on for two days straight no problem.
Nov 2, 2017 at 4:45 AM
LEX215
Just want to know why it is doing that?
Nov 2, 2017 at 4:46 AM
  • 110,248 POSTS
If it is working properly again, I would suspect a corroded connection at the battery. Make sure the terminals are clean and tight.
Nov 2, 2017 at 11:45 AM
  • 55,721 POSTS
When the engine will not start we must see if it is fuel related or spark? Here are two guides that will help us see whats going on. When the engine will not start do you hear the fuel pump in the tank going?
and
Please let us know what happens so it will help others.
Cheers, Ken
Nov 3, 2017 at 6:10 AM
