Abs issue
210,000 MILES • 3.4L • 6 CYL
ERNEST WALKER
Anti lock light and trac control light are on. Hooked my car to a code reader and issue are speed sensor related. Can I use just a speed sensor harness or must I get a front hub assembly?
Oct 31, 2017 at 12:01 AM
STEVE W.
  • 15,418 POSTS
That depends on what is actually damaged. If it is a broken wire in the harness before the sensor connector then you replace that. If it is a bad connector then it depends on which side. If it is the wiring or the sensor after the connector you replace the hub as the sensor is part of it and is not available as an individual part.
Oct 31, 2017 at 12:37 AM
