Dashboard ABS light message?
80,000 MILES • 1.4L • 2WD • AUTOMATIC
MWEBS
On the dashboard of a VW Touran 2014, i get on the dashboard, the ABS light. I have used the ANCEL VD500 to read the diagnostics and below are 6 codes for ABS reported.
-01314. Engine Control Module
-Left front ABS wheel speed sensor
-Right front ABS wheel speed sensor
-01130 ABS operation
-01317 Instrument cluster control module
-03095 Diagnostic interface for data bus coded incorrectly.
I am also getting these other fault codes.
steering angle
central electric
-06012 CLUTCH 2, tolerance limit reached
-06279 vehicle speed signal wheel speed from brake control module - implausible signal
Please advise on how I can have these fixed. Thank you.
Dec 24, 2023 at 9:34 PM
  • 55,694 POSTS
Was this car in a flood? It sounds like you could have a problem with the CAN system of the car, let's clear all the codes and then turn the system on without starting the engine and then run the codes again to see what comes up. What we are trying to do is see which codes are more prevalent than the others so we can get a clue on what the problem is. I have seen the instrument cluster cause problems like this, but I want to see if the cluster code comes up first.
Dec 26, 2023 at 2:34 AM
MWEBS
I re-run the diagnostics and below is what comes up.
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Not registered 0011
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
2 Faults Found:
006012 - Clutch 2
P177C - 001 - Tolerance Limit Reached - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 7
Reset counter: 9
Mileage: 71282 km
Time Indication: 0
Date: 2018.04.11
Time: 11:13:54
006279 - Wheel-Speed Signal from ABS Control Module
P1887 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 4
Reset counter: 4
Mileage: 71287 km
Time Indication: 0
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 333B4016212206FFCC1302ED84206080310000
Shop #: WSC 01357 011 00200
VCID: 7DA7F5872DF751C2445-8028
6 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 110
Mileage: 71228 km
Time Indication: 0
Date: 2018.03.29
Time: 10:16:49
Freeze Frame:
Count: 7
Count: 14
Count: 28672
Count: 8196
Count: 42240
Count: 512
Count: 65027
Count: 129
00283 - ABS Wheel Speed Sensor; Front Left (G47)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 3
Reset counter: 117
Mileage: 71099 km
Time Indication: 0
Freeze Frame:
Count: 7
Count: 15
Count: 12288
Count: 40
Count: 31488
Count: 63744
Count: 64769
Count: 128
00285 - ABS Wheel Speed Sensor; Front Right (G45)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 124
Mileage: 71404 km
Time Indication: 0
Freeze Frame:
Count: 7
Count: 15
Count: 12288
Count: 56
Count: 34560
Count: 1280
Count: 64769
Count: 127
01130 - ABS Operation
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 50
Mileage: 71033 km
Time Indication: 0
Date: 2018.02.23
Time: 14:56:32
Freeze Frame:
Count: 2
Count: 14
Count: 28672
Count: 124
Count: 43264
Count: 57088
Count: 0
Count: 120
03095 - Diagnostic interface for databus (J533) implausible messa.:
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 50
Mileage: 71033 km
Time Indication: 0
Date: 2018.02.23
Time: 15:04:02
Freeze Frame:
Count: 7
Count: 14
Count: 28672
Count: 8256
Count: 44288
Count: 57344
Count: 0
Count: 73
01317 - Control Module in Instrument Cluster (J285)
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 50
Mileage: 71033 km
Time Indication: 0
Date: 2018.02.23
Time: 15:04:02
Freeze Frame:
Count: 7
Count: 14
Count: 28672
Count: 8201
Count: 44288
Count: 57344
Count: 0
Count: 73
Address 19: CAN Gateway (J533)
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 180
Reset counter: 255
Mileage: 71033 km
Time Indication: 0
Date: 2018.02.23
Time: 15:04:03
These are some of the issues noted while driving the car.
1. losing power on acceleration sometimes before picking up sometimes with a burst of power.
2. sometimes car rolls back when proceeding from a stop while uphill or rolls forward when reversing on a slope
Please advise how to proceed.
Jan 2, 2024 at 9:04 PM
  • 55,694 POSTS
So, was the car in a flood or is the wiring messed up? Is this a race car?
You didn't start the engine before running the codes correct? To me to sounds like the ABS control module has gone bad, here is how to replace it. This problem is not obvious, if you want to take it to the dealer, I would not blame you. Check out the images (below). Please let us know what happens.
Jan 3, 2024 at 1:46 AM
MWEBS
Thank you for writing back.
no it wasn't in a flood. it has a sun roof and had a leakage at one time with water in the boot, also went over the carpets in the passenger area. It is not a race car.
No. I didn't start the engine before running the codes.
so we replace the ABS control module.
what about these 2 codes on the Auto Trans?
2 Faults Found:
006012 - Clutch 2
Freeze Frame:
Jan 3, 2024 at 3:31 AM
  • 55,694 POSTS
For the clutch problem please start a new thread because we only handle one problem per. Since there is a Wheel-Speed Signal code let's check the sensors manually.
Here is a guide to help:.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Please go over this guide and get back to us.
Jan 3, 2024 at 11:20 PM
