Some progress. Please bear with me while I explain what happened. I need another brain and set of eyes to figure out something.
-Initially, both front wheel sensors were reading 0.
-Initially, all wheels showed a signal of 100% (not sure how is this measured or when, but the scanner has an option to "signal check" and they all showed 100% initially.
-Aftermarket Amazon wheel sensors did nothing to show any speed change from 0.
-Same aftermarket sensors showed 0% signal when I did the "signal check".
-Installed the new wheel bearing with the old sensor and turned ignition on, turned wheel by hand and there was no change in speed (not sure if it can be generated this way with these Hall effect sensors), BUT the signal check was at a 100%.
-Installed a new sensor from a good company, good brand, put everything back and put the car down. Back out of garage. Deleted all codes, immediately all lights returned. One was for rear left the other front right. Deleted again, only front right remained.
Drive the car while looking at wheel speeds, one of those that was showing 0 is now working great, but it is saying it is the right one, not the left that I changed. ugh.
-So, is it possible that the one on left is showing on right?
Does not make any sense that after a new bearing and sensor that the right one starts to work and not the front left....this is crazy..
-Not sure why the picture won't load, but it is basically showing 2 codes:
480713 permanent: WSS:Plausibility, right front direction of rotation.
480A9C permanent: WSS left rear sporadic fault.
Feb 4, 2022 at 7:58 AM
