ABS light flickering on and off
110,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
EZEX
  • 53 POSTS
The ABS light has been flickering on and off for a while. My front 2 hubs and brakes were replaced a while ago, before the ABS started. My rear 2 hubs both had play and the brakes needed to be replaced anyway, so I just replaced them. I was hoping that would solve the problem. It didn't. I haven't scanned it yet but have access to a Bluedriver if I need it.
May 9, 2022 at 10:59 AM
SQM
  • 6,383 POSTS
ABS light can come on due to a sensor, wiring issue or faulty module.
Since the ABS light is being illuminated, a good first step would be to scan and retrieve the code(s).
This can help you determine what might be the cause.
Here is a helpful guide:
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Let me know what code you find or if you have any questions.
May 9, 2022 at 3:17 PM
