ABS fault codes
58,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
WERNER1
While driving, the ABS light comes on, and after a while, it turns off. I do not have an OBD scanner, and I would like to check if there is any ABS code stored. I know older Honda models have a 2-pin service check connector somewhere on the passenger side. I attempted to find it on this 2014 model to no avail. Can you help me find this connector on this 2014 Accord?
Thank you, kind,
Werner
May 3, 2022 at 3:15 AM
  • 110,251 POSTS
The connector you are referring to was on pre-1995 Honda vehicles (OBD1). There was a diagnostic two-terminal blue connector used to trigger the code display mode, which is located on the passenger's side, under the dash.
After 1994, the vehicles were equipped with an OBD 2 system that requires a scan tool to retrieve codes.
Because the vehicle is newer, I recommend scanning the can-bus. If there are issues with ABS faults, the codes will be stored in the ABS module. A traditional scan tool won't retrieve codes from that module. Here is a link explaining how it is done:
You could try at a local parts store because most will scan for free, but most times they won't have a scanner that can read the can-bus.
Let me know if this helps or if I can help in any way.
May 3, 2022 at 12:27 PM
WERNER1
Thank you for your message. It is really appreciated.
Werner
May 5, 2022 at 6:17 AM
  • 110,251 POSTS
You are very welcome. Let me know if I can help in any way.
May 5, 2022 at 1:18 PM
