ABS, traction, engine lights are on after the car being hit on the right side
80 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ALAAEDIN
after a hit to the right front side of the car, the ABS, traction, engine lights are on, and the diagnostic is reading changes in 3 out of the 4 wheels except one which is stuck on a fixed number. I changed the wheel sensor and still . what could it be?
Mar 21, 2021 at 9:09 PM
Good morning,
Did you change the sensor on the wheel that has damage?
I attached the procedure below for you to view.
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
2014 - Mazda6 - Brakes
FRONT ABS WHEEL-SPEED SENSOR REMOVAL/INSTALLATION
1. Remove the mudguard.
2. Remove in the order indicated in the table.
3. Install in the reverse order of removal.
4. After installation, verify that there is no twisting in the front ABS wheel-speed sensor.
Front ABS Wheel-speed Sensor Wiring Harness and Clip Disconnection Note
NOTE:
- Refer to this note only if the disconnection of the front ABS wheel-speed sensor wiring harness and the clip shown in the figure is required.
1. Insert a flathead screwdriver from the side where there is no notch as shown in the figure.
2. Detach the tab as shown in the figure and disconnect the ABS wheel-speed sensor wiring harness and clip.
Mar 21, 2021 at 9:44 PM
ALAAEDIN
Thank you for your reply. yes, I replaced the sensor and still having the same issue. just the hit broke the ABS unit plug so the mechanic wired the sensor directly to the unit cable.
Mar 21, 2021 at 9:56 PM
That was not a good idea at all. The wires are so thin that joining them is very difficult.
Can you give me the code that was set?
Mar 21, 2021 at 9:57 PM
