Code C1226(1/1), ABS light on?
125,000 MILES
SD F250
Pulled into the yard and stopped, when I looked at the dash the ABS light came on. using my code reader, it stated the "The brake Warning indicator Output Short Circuit to ground?
Aug 26, 2023 at 1:37 AM
  • 55,604 POSTS
The Diagnostic Trouble Code (DTC) C1226 related to the right rear excessive wheel speed variation during ABS (Anti-Lock Brake System) operation.
Aug 26, 2023 at 12:20 PM
SD F250
The fuse filament came loose from one side. I changed the fuse, the light went off and the gear shift is working.
Aug 28, 2023 at 5:51 AM
  • 55,604 POSTS
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Aug 28, 2023 at 5:52 AM
