Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
G6
Brakes
ABS
Module
Replace/Remove
The battery drained after replacing the ABS Control Module
2007 PONTIAC G6
3,162,362 MILES • 3.5L • V6 • TURBO • 2WD • AUTOMATIC
RICKY FERLIN GOODVOICEFLUTE
MEMBER
1 POST
Replace ABS module with a used one programed battery drained.
Mar 23, 2022 at 9:15 AM
Experienced Mechanic
Which battery drained? Is it the primary power source for the car under the hood or a stave alive module battery?
Let me know. Let me know as much as you can about the issue to help make a diagnosis.
Mar 23, 2022 at 11:53 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
