Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Durango
Brakes
ABS
Module
ABS control module programming
1999 DODGE DURANGO
187,134 MILES • 5.9L • V8 • 4WD • AUTOMATIC
JOHN UHTOF
MEMBER
1 POST
I ordered a new control module with the exact same serial number. Will it still need to be reprogrammed?
Jun 10, 2018 at 10:34 PM
Experienced Mechanic
Good evening.
Yes, it needs to be programmed to your vehicle. The VIN number needs to be entered into the module.
You can check with different shops. Many of them do this service. The dealer is a last resort and very expensive.
Jun 11, 2018 at 9:51 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
