the ABS light failed to go off
85,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
LJULCOQ
First the ABS light failed to go off and then an hour later the brake light did the same. I have been told I have to replace the whole system at a phenomenal cost. I was just wondering.
Jan 17, 2019 at 10:13 AM
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Here is a guide that will help as well on how to replace this:
https://www.2carpros.com/articles/how-to-replace-a-abs-controller
Below you will find the process on how to replace this from the manual which will provide the info that you need.
let us know if you have other questions. Thanks
Mar 13, 2021 at 8:22 AM
