ABS, brake assistance, cruise, power steering, and speed meter stopped working
2012 TOYOTA CAMRY HYBRID
222,111 MILES • 2.5L • 4 CYL • FWD • AUTOMATIC
MALATRAB
After I stooped by a place, the engine still running all the following lights came on:
1- Electric power steering system
2- Slip Indicator
3- ABS
4- Traction control off indicator
"there is no check engine light"
The car still run and drive, but the engine feels weaker, no ABS, no cruise control, no power steering, and speed gauge and RPM arn not working.
I got the following codes:
1- P1E03
2- P0171 SYSTEM TOO LEAN (bANK 1)
3- C3200
4- P0012 Inteak Camshaft Position Timing - Over - Retarded (bank1)
5- P1600 1.x manufacter control P16 Computer and auxulary outputs 2. ECM BATT malfunction
6- P0032 HO2S heater control circuit high (Bank 1, Sensor 1)
7- P3700
8- P0101 Mass or Volume Air flow circuit range/performance
9- P0201 Injector circuit / open cylinder 1
10- P0106 Manifold Absolute pressure/ BARO sensor range/ performance
11- P1101 Atmospheric press sensor circuit range/ performance
12- P011B Engine control temperature /intake air temperature correlation
13- P2501 Generator Lamp/L - terminal circuit high
14- P0136 O2 circuit (Bank 1, Sensor 2)
15- P3701
16- P0139 O2 circuit slow response (Bank 1, Sensor 2)
17- U0129 Lost communication with break system control module
Thank you in advance
Dec 9, 2016 at 5:05 PM
  • 31,937 POSTS
Clear all code, get battery load tested and check charge rate. this may be due to a low battery threshold limit, let me know what you find.
Dec 9, 2016 at 11:37 PM
MALATRAB
Thank you MHPAUTOS, I will try and tell you what happens,
Dec 10, 2016 at 5:03 AM
