Replaced the ABS module and Master Cylinder, the brakes still no brake pedal?
140,000 MILES • AUTOMATIC
YUDIMI
changed ABS module and master cylinder and still no brake pedal.
Feb 21, 2023 at 1:53 AM
  • 55,721 POSTS
Did you have no brake pedal before you started? Or after? Also did you bench bleed the system before you installed it? Either way it sounds like there is air inside the brake ABS system which needs to be removed to get your pedal back. This must be done with a scan tool.
Please check out this video below:
https://youtu.be/nQRnKyVyMuQ
The only other thing that can be causing it would be a brake caliper that is frozen on its slides, so please remove the tires and inspect the slides.
This guide can help as well:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Please go over these guides and report back.
Feb 21, 2023 at 7:35 AM
