ABS light is on and brakes do not work at all
293,000 MILES • 4.4L • 4 CYL • 2WD • AUTOMATIC
TAMMIDINGMAN67
Where is ABS fuse box? Passenger side wont bleed. Not losing any fluid from reservoir. Help! Cannot afford a mechanic.
Jan 11, 2019 at 7:05 AM
  • 110,251 POSTS
The ABS fuse and relay box is under the hood on the passenger side. See picture 1. Let me know what is happening. Is the brake pedal going to the floor? I have to be honest, if the ABS light is on, that shouldn't prevent the brakes from working. It will, however, prevent the ABS from working.
Apr 23, 2021 at 6:19 AM
