Abs brakes
65,000 MILES
HELEN ROMASIEWICZ
Washed car then ABS lights went on and others car stuck in park?
May 16, 2017 at 10:16 PM
HMAC300
  • 48,601 POSTS
a mechanic will have to scan for codes on this it may be a sensor bad. make sure you press on brake to release so it will go out of park. then check fuses under hood and in dash as you may have blown a fuse.
May 17, 2017 at 12:01 AM
