ABS brake system not bleeding after putting new brakes on all the way around including calipers.
Jan 1, 2018 at 7:54 AM
✓Experienced Mechanic
Good morning.
The ABS system needs a scan tool to bleed the unit. It cannot be bled without the scan tool. Any shop should have this tool and be able to bleed the system for you. It takes about fifteen minutes. If you have a fault code or if the ABS light is on, the procedure will not work until the fault is repaired.
