ABS and brake lights come on
73,000 MILES • 0.6L
DARLA K DOUGHERTY
ABS and brake lights come on. Air conditioner and signal lights quit working about every other time I start the truck. Any suggestions?
Aug 13, 2018 at 12:35 PM
Good morning.
The ABS system has stored a fault in the system. We need that fault or code. once we know the code, we can help narrow down the area of failure.
One quick check is to verify the fluid level in the master cylinder.
As far as the AC and the lights, verify all your fuses are good by checking for power on both sides with the key on with a test light.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Apr 27, 2021 at 3:23 AM
