ABS brake module removal issue?
195,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
SHADETREE1952
I am trying to remove the ABS brake module to send for repair. I am unable to release the big electrical cable. I was able to unlock and swing the hinged portion of the cover, but the whole unit of wires remain in/attached to the module.
Jun 24, 2023 at 8:38 AM
  • 110,248 POSTS
The only thing that holds the connector is the hinged connector lock you mentioned. Oftentimes, the connector is corroded and tight. Have you tried wiggling it and pulling it straight outward?
Jun 24, 2023 at 3:24 PM
