ABS and brake lights flashing intermittently
114,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
SEAN HANNON-BARRY
I drive the truck listed above 1500. When I start up the ABS and brake light will come on with the accompanies warning sound. They will then extinguish until I select a gear then once moving they will come and go intermittently.
I have had this problem for about ten days now. I have checked fuses and fluid levels. I have ordered a new ABS module but was wondering if there were any more recommendations to get to the bottom of this issue?
Nov 29, 2018 at 3:50 AM
Good afternoon,
Wow, expensive guess.
Did you have it scanned for an ABS code? It could be a wheel speed sensor that is turning on the light.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Mar 1, 2021 at 4:38 AM
SEAN HANNON-BARRY
Hi Roy.
I took it to AutoZone and they plugged in their tester. There were no codes.
SEAN HANNON-BARRY
Roy.
I plan on checking out each wheel speed sensor this weekend. Hopefully it will bring forth a fix or at least narrow the troubleshooting a bit.
Okay, did AutoZone scanner read ABS codes? A lot of the parts stores only read engine codes.
