ABS brake control module
118,500 MILES • 5.3L • V8 • 2WD • AUTOMATIC
SAVITAS
It is bad, my mechanics says it is no good, where can i have it repaired? is it repairable?
May 23, 2019 at 5:56 AM
Hi Savitas,
Depending on what failed on the module it is possible to have them rebuilt or refurbished. However, I would not recommend this because in most cases by the time you send it off and have it determined whether or not it can be fixed, you would have been able to have the ABS module replaced and the vehicle returned.
It is normally cheaper to have it repaired but again, if it were me, I would just replace the module.
To find these services in your area, you will need to perform an internet search for ABS module rebuild services. There are a number that come up. I would normally send you a link but I have never used one of these companies so I don't want you to think I would recommend one over the other.
Hopefully this answers your questions. Please let me know if you have others. Thanks
Mar 11, 2021 at 5:25 AM
