Replaced front ABS sensors , ABS and anti skid lights stay on on and off anti skid button will not work?
Nov 12, 2020 at 12:48 AM
✓Experienced Mechanic
Good afternoon,
There is a fault stored in the system. We need that fault. You can stop at a parts store and see if they can read the ABS system for faults. It sounds like you may have a wheel speed sensor that is out. These videos will help us find the problem.
Please run down these guides and report back. Once I get that code, I can help track down the area of failure. Once the ABS is repaired, all the other systems will work again.
Nov 12, 2020 at 5:56 AM
Have you checked for codes? If so, what are they because that is going to tell us where the issue is.
Thanks for your help. after I changed the sensors , the lights where still on, but then i drove it down the road and wow, they went out. so everything is fine. thank you again for your time....
Nov 12, 2020 at 7:17 PM
The ABS system self checks when you first start it. When the repair is successful, the light goes out when you get to 8 MPH.
