ABS and traction lights are on
26,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
HANIIRAQ
  • 5 POSTS
Good day.
I connect obd2. 4-13 port and counts the ABS light flash the code is 95 .
and the traction light flash as code 43
please i want to know the issue to fix it .
Thank you
Apr 9, 2020 at 6:22 AM
  • 110,248 POSTS
I looked up the codes you indicated. Code 43 doesn't indicate to be a traction control code, and code 95 doesn't show at all. Are you sure these are the codes? See pictures below.
_____________________________
First, and don't laugh, make sure the brake fluid level is full.
I can tell you that most tomes there is a traction control and abs light on at the same time, it is related to a wheel speed sensor. Do you have access to a live data scan tool? If so, you need to check for signals from each wheel speed sensor.
Now, if you don't have a scanner, you can check each speed sensor using a multi meter. Here is a link that shows how that is done:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
If you look at pics 3 and 4, they show the location of the speed sensors on your specific vehicle. There will be one at each wheel. I will tell you that if a rear sensor is bad, you will need to replace the hub bearing assembly. It is a sealed unit. The front is easier and only requires the sensor.
If you have questions, let me know. Also, if you are able to check these and find one is bad, let me know that as well. I'll help you through replacement.
Here are a couple links you may find helpful when testing:
Let me know what you find,
Apr 9, 2020 at 9:11 AM
HANIIRAQ
  • 5 POSTS
very thanks for replay I will doing your advise and tell you the results .
Thanks
Apr 9, 2020 at 7:13 PM
  • 110,248 POSTS
You are very welcome. If you have a chance, let me know. It may help others in the future when they see your post.
Take care of yourself and I wish you and your family a Happy and Healthy Easter.
Apr 10, 2020 at 11:11 AM
HANIIRAQ
  • 5 POSTS
Good day Mr. Joe.
I hope you and your family always health and be safe .
I got to test my Corolla by computer and found this issue in ABS system; lost communication with acceleration speed sensor.
I forget to tell you that the airbag module not found did this make all this issue?
can tell me how I fixed this issue? Thanks for your help and time .
Hani
Apr 13, 2020 at 9:17 PM
  • 110,248 POSTS
I hope you are doing well also. Okay, since you had it scanned, is there a specific diagnostic trouble code that was found? There are a few different directions we can go with the idea of a communication loss. It still could be a wheel speed sensor or even a transmission speed sensor. As far as the airbag, no. That wouldn't cause the ABS issue.
Apr 14, 2020 at 2:14 AM
HANIIRAQ
  • 5 POSTS
Good day Mr.Joe.
I got an airbag module and connect it to its harness and all my issues was gone.
my ABS light gone .
my seat belt light work.
my radar also work.
i think the seat belt light related to airbag module and the ABS related to airbag module (yaw sensor) and the radar related to ABS . if remove the airbag module will affected on all of this electrical components?
Thanks for you cooperation.
Hani
Apr 23, 2020 at 8:20 AM
  • 110,248 POSTS
Hello Hani,
I'm glad you got that fixed. And yes, they are all tied together. Is everything working properly again?
Apr 23, 2020 at 11:36 AM
HANIIRAQ
  • 5 POSTS
Hello Joe,
Yes , when I connect the airbag module everything working properly again.
Hani
Apr 23, 2020 at 5:49 PM
  • 110,248 POSTS
I'm glad to hear it. Take care and feel free to come back anytime.
Apr 24, 2020 at 11:04 AM
