ABS and traction control light
135,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
ALEXTTT
  • 59 POSTS
My ABS and traction control light came on. Are these lights referring to one of the wheel hubs sensor?
Mar 29, 2020 at 1:18 AM
Yes. More than likely this is one or multiple of the speed sensors. However we need to check codes in order to confirm this and find out which one.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
If you can't pull codes, you can find a parts store that does it for free and just let us know what the code is and we can go from there. Thanks
Mar 29, 2020 at 1:23 AM
