ABS and traction control are staying on after wheel hub replacement
150,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
STORM91
The car had a bad wheel hub on the right rear side so I bought the wheel hub to replace it. after it was put on ABS and traction control stay on and kicks in while driving. Well, I thought maybe the ABS sensor was bad. so I replaced it had the lights reset afterwards then after that it popped back on while driving again. so I replaced the VDC relay switch thinking maybe that had something to do with it. still didn't work. I'm out of ideas and money trying to fix this problem. on a OBD scanner it throws a code right ABS sensor. none of this happened until I changed the wheel hub out and yes it is 4 wheel ABS.
Feb 22, 2021 at 4:05 AM
Couple things. First can you provide the specific code you are getting for this? Also can you provide the part information for the hub that you replaced? I am thinking that you replaced the hub with a non ABS part or the hub is faulty in some other way.
Here is a guide on replacing a hub in case you or others need it:
https://youtu.be/ZgiPRG6jffc
However, if you can provide the code and then we can run through the testing.
Also, here is a guide that will help with a general test on a wheel speed sensor:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
As you can see, I suspect the issue is with the part we just need to figure out what it is so that we know if you need to replace it again or not. Thanks
Feb 22, 2021 at 6:59 AM
STORM91
I will let you know by the end of the day for sure because I'm going back up to that shop in a little while.
Feb 23, 2021 at 2:47 AM
Sounds great. Thanks for the update. We will be here whenever you get back to it.
Thanks
Feb 24, 2021 at 11:08 AM
