ABS and Stability control turn on?
165,400 MILES • V6 • 2WD • MANUAL
SOHNIA
So, I have recently changed both back and front sensors and reset the codes, but it still pops up. Is there any way I can get it to turn off?
Nov 30, 2022 at 2:08 PM
  • 55,694 POSTS
Which code is it? you might have an ABS control module that is out. When you say you replaced the wheel speed sensors did you do the bearing hubs as well? Please let me know here is a video to show you how to get the codes in case you need them.
https://www.2carpros.com/articles/anti-lock-system-testing-and-repair-abs
Please go over this guide and report back.
Dec 1, 2022 at 9:09 AM
