ABS and parking brake warning lights will not turn off
1993 DODGE DAKOTA
200,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
BUBBA KELLEY
Okay, so when both lights are on my truck wont move at all. When lights go off which will only be few seconds then back on it will roll.
Aug 3, 2021 at 11:34 AM
CARADIODOC
  • 34,384 POSTS
Can you please explain this problem a little more? Anti-lock brakes is an add-on system to the regular brakes. When the yellow warning light turns on, the entire ABS system is deactivated and will have nothing to do with driving the truck. You treat it like that system isn't even there.
Aug 3, 2021 at 11:42 AM
This sounds like an active ABS issue that is locking the wheels. This could be a wheel speed issue or even a module issue. When you say both lights I assume you are saying the brake light and ABS light?
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
https://www.2carpros.com/articles/brake-system-warning-light-on
However, we need to start with checking for codes and find out what is there when this is happening.
Here is a video that will help with this:
https://youtu.be/rTtAnsOlZU4
Also, here is a guide on possible wheel speed issues as that is the likely issue since this seems to act up once you move:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
I would suggest testing the wheel speed sensors depending on what codes we get.
Let us know what you find with this and we can go from there.
Thanks
Aug 4, 2021 at 6:51 AM
CARADIODOC
  • 34,384 POSTS
The reason I asked for clarification is this is a very basic RWAL system that only uses one speed sensor in the top of the rear differential. The controller is only capable of storing one diagnostic fault code at a time, and I have never seen a scanner or code reader other than Chrysler's DRB2 that can read the codes and erase them. That may have changed by now, but when I was at the dealership in the '90s, Snapon, for one, didn't see much of a market for adding it to their capabilities. Even disconnecting the battery doesn't erase the fault code.
Based on the red warning light being on, my guess is a parking brake cable is rusted partially-applied. Since rear drum brakes are "self-energizing", a dragging parking brake will make that brake self-apply when trying to drive forward. The truck will usually be able to move rearward. The first clue is the red light will turn off if the parking brake pedal is pulled up by hand.
The second clue, while this wasn't actually stated, is it is implied the warning lights do not turn on at times. If a hard defect occurs, the yellow ABS warning light will stay on all the time. It only turns on intermittently when the red warning light turns on. There's three inputs for the red light. Those are the parking brake switch, the low-fluid level switch in the reservoir, and the pressure differential switch. That red light is an input to the ABS controller. That controller turns the yellow warning light on and turns the ABS system off any time the red light is on. It doesn't know why the red light is on. It only knows there's a pretty good chance it can't perform properly, either due to a leak in half of the system, loss of brake fluid in general, or a drum brake that won't cycle and release properly.
This system used a "dump" valve and an isolation valve up by the master cylinder. It could block additional brake fluid pressure to the rear wheels, and it could bleed off some of that pressure if it saw them slowing down too quickly. There was no pump to reapply pressure as there is in 4-wheel-ABS systems, so no defect could apply the brakes. A quick way to know this is an RWAL system is the brake pedal will gradually drop closer to the floor when a rear-wheel skid is initiated.
The 4-wheel-ABS system didn't show up until the '94 model year. Those did use a pump to reapply pressure. The clue there is the brake pedal can get pushed back toward the driver while it's modulating brake fluid pressure. You'll feel vibrations in the brake pedal too. These 4-wheel systems didn't become common until around the '95 to '97 model years. I don't remember working on this system. I do remember as late as 1995 the RWAL system still needed the DRB2 to read and to erase fault codes. The next version, DRB3, might do that too with one of the plug-in "Supercards" that lets it work on models as far back as 1983.
The bottom line is this sounds like while there might be a problem with the ABS system, it is likely not the cause of the failure to move. It sounds like a symptom or clue.
Aug 4, 2021 at 11:28 AM
