ABS and Parking Brake light on
209,800 MILES • 5.3L • V8 • AUTOMATIC
BIVINSP
c0265 chevy abs history solenoid valve relay circuit is what's showing on meter, replace the sensor in front tires. can you help to fix the problem, by telling what part to buy, or info on fix it you self.
Dec 2, 2013 at 9:50 PM
HMAC300
  • 48,601 POSTS
c0265 is an internal abs unit problem. so the abs needs to be replaced. cheapest way for you to do this is to remove abs and send it in for a rebuild, check online for prices or check with auto parts as the truck will need to be laid up for a while. This video will how you how
https://youtu.be/lUotkKXG9dY
then you'll need a pro to bleed the system due to he will need to use a scanner to hold valves open in abs to bleed it properly.
Mar 13, 2021 at 3:42 AM
