ABS and master cylinder
253,000 MILES • 1.6L • 4 CYL • FWD • AUTOMATIC
COREY H JENKINS
  • 80 POSTS
How do I tell if the car has ABS or not? I was told it made a difference when replacing the master cylinder. Mine has a wire harness hooking up on the bottom of reservoir, not connected at all to master cylinder. Also, how does the reservoir detach from the master cylinder?
Apr 24, 2017 at 8:36 AM
HMAC300
  • 48,601 POSTS
see picture. if you have where arrow points under hood you have ABS if not you do not. reservoirs are either just sitting on master with o-ring attachment or screws that may be on bottom. See picture.
Apr 24, 2017 at 11:36 PM
