ABS and brake lights come on at the same time
142,000 MILES • V8 • 2WD • AUTOMATIC
FOXDEN
  • 22 POSTS
And will stay on until the engine is turned off. When the engine is started the lights will be off, they may come back on in a few minutes or an hour or not at all. But will eventually come back on.
I watched a video that had mentioned cleaning the grounds. I have cleaned both back down to bare metal. Did not help.
It has plenty of brake fluid and the code reader shows no codes.
Any suggestions?
Thank you
Oct 11, 2019 at 12:04 AM
  • 110,246 POSTS
Welcome to 2CarPros.
Most basic code readers won't read ABS codes. I'm not sure what you have. I will say that most times there is an issue like you described, there is a problem with one of the wheel speed sensors. There are two ways you can check. First, if you have a live data scanner that can read ABS signals, watch to see if when the light comes on if there is a variation between what each sensor is indicating the speed to be. For example, three of the sensors say 40 mph and one says 10 mph.
Other than that, you can check if the sensors are working by checking for an AC signal from them using a multi meter. The problem I see with this technique is that the light doesn't stay on all the time and what triggers it seems to be variable.
Here is a link that shows how to test a wheel speed sensor in case you want to try it:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Here are a few links you may find helpful when testing:
I attached an exploded view of the front sensor. There will be one on both sides.
________________________
Oct 11, 2019 at 12:45 PM
FOXDEN
  • 22 POSTS
I checked the front sensors for ac voltage and they are both putting out at around 1.9. have not located rear wheel sensors. Lights still coming on.
Oct 15, 2019 at 4:13 AM
FOXDEN
  • 22 POSTS
Code reader reads ABS. there were no current codes.
History codes were:
po226 left front wheel speed signal missing
po222 right front wheel speed signal missing
po265 electronic brake control module motor relay circuit
Oct 15, 2019 at 10:23 AM
  • 110,246 POSTS
Welcome back:
Those voltages sound good. Now, the rear is a different story. The input signal for rear wheel speed originates at the vehicle speed sensor (VSS). This sensor is what sends the signal to identify vehicle speed via the speedometer. So, if there is a problem with the VSS, chances are you will notice something is off with the speedometer. I attached a picture of the sensor and where it's located so you can see which one it is.
In the picture, sensor 2 is the output speed sensor and the one I'm referring to.
Are you having any issues with the speedometer?
Oct 15, 2019 at 10:24 AM
FOXDEN
  • 22 POSTS
Good morning,
The speedometer and odometer are working fine.
I looked under the truck and the sensors are different from the diagram. There is one on the drivers side which I believe for the transmission and one on the opposite side I believe my be the speed sensor. It has 2 leads. I am attaching pictures. The small sensor I took an ohms reading 1.8. The leads to showed no reading with the ohms.
Did you receive my 2nd reply yesterday about the old codes?
Thank you
Oct 16, 2019 at 2:46 AM
  • 110,246 POSTS
Welcome back:
I need which v8 you have to confirm transmission. Also, I did see the codes. Since both front sensors have no signal and you have the C0265, I suspect there is no voltage to the electronic brake control module. Take a look at the attached pic. Check that.
Also, the sensor you have on the work bench appears to be the speed sensor. Pic 3 looks like the transmission range sensor.
If you look at pics 2 and 3, they are the entire flow chart. Here is additional information you may find helpful. However, take not of the specific one related to the problem. Most likely, there is a connection issue at the control module.
________________________________________________
Steps 6 of 11
Circuit Description
The ABS relay supplies battery voltage to six valve solenoids. The EBCM microprocessor applies the grounds needed to activate each solenoid. The low side of each solenoid coil has a feedback circuit to the EBCM microprocessor. When a solenoid is commanded OFF, the feedback voltage is high. When a solenoid is commanded ON, the feedback voltage is low.
Conditions for Running the DTC
^ The ignition is ON.
^ The vehicle speed is greater than 6 km/h (4 mph).
Conditions for Setting the DTC
The EBCM detects an internal malfunction.
Action Taken When the DTC Sets
C0265
If equipped, the following actions occur:
^ The EBCM disables the DRP/ABS.
^ The ABS indicator turns ON.
^ The brake warning indicator turns ON.
C0266
^ The EBCM disables the ABS
Conditions for Clearing the DTC
The conditions for setting the DTC are no longer present and you use the scan tool Clear DTCs function.
Diagnostic Aids
Important: Whenever the EBCM is replaced for DTC C0265 or C0266, the ABS pump motor and motor circuitry must be tested for the proper resistance. Refer to steps 7 and 8 in the diagnostic table below for testing procedures and resistance values.
C0265
Thoroughly inspect connections and circuitry that may cause an intermittent malfunction.
C0266
Replace the EBCM if DTC C0266 continues to set intermittently.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
4. This step tests if the battery positive voltage circuit can supply adequate power to the system relay.
7. A shorted ABS pump motor or shorted motor circuitry may damage the contacts within the system relay. Follow this step to prevent damage to a replacement EBCM.
The last 3 pics I added show the ECBM connectors and what the pins are for.
__________________________________________________
Let me know if this helps and what you find.
Oct 16, 2019 at 11:14 AM
FOXDEN
  • 22 POSTS
There is power to the EBCM. The pump shows 0.4 ohms. Still no current codes showing.
The lights went off for a couple of days, came back on today. turned off engine. When started back up, lights off.
Oct 23, 2019 at 5:32 AM
  • 110,246 POSTS
Welcome back:
Have you confirmed that all connections are tight and not corroded?
Oct 24, 2019 at 10:26 AM
FOXDEN
  • 22 POSTS
Yes I have.
Oct 24, 2019 at 10:06 PM
  • 110,246 POSTS
The only thing left is the ABS module. Just for the heck of it, and don't laugh, check the brake fluid level. I have seen low fluid turn these lights on with similar conditions.
I understand you most likely already have done that, but I had to ask.
Oct 25, 2019 at 10:12 AM
FOXDEN
  • 22 POSTS
The fluid is full. Lights have not come on for a couple of days. If they do I guess it is time to break down and by a new ABS module.
Thank you
Oct 28, 2019 at 1:45 AM
  • 110,246 POSTS
Welcome back:
You are very welcome. I'm glad it hasn't come on. Lets hope it was a one time deal. Let me know if you need anything.
Oct 28, 2019 at 11:24 AM
