ABS and brake light turn on
261,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
CESALI ANDERSON
My ABS and brake light intermittently come on. I have noticed it comes on a lot when pressing my brake. What should I check first?
May 6, 2021 at 3:30 PM
Good morning,
I would have the codes checked first as it will help narrow down the area of failure.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
It may be a sensor that is the most common failure.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
May 6, 2021 at 10:10 PM
