ABS and brake light on and codes 24 and 22
141,000 MILES • 4 CYL • TURBO • 4WD • MANUAL
NASER NASER
  • 836 POSTS
Bought the car listed above sti model, which has ABS and brake lights on, has these codes. Is it possible all are bad and were just ignored?
Mar 30, 2020 at 7:23 AM
Normally not. Normally this is indicative of an ABS module issue. However, they are all related and the OEM has included them in one test which I attached.
We need to run through the test just to confirm the issue. Clearly there are other issues and possibly each one has failed but again, highly unlikely. I fully expect you will find one issue causing all these codes.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Let me know what you find. Thanks
Mar 30, 2020 at 7:32 AM
NASER NASER
  • 836 POSTS
They talk about gap adjusting. is that using the spark plug gap? Because i saw a couple of them in the glove box.
Mar 30, 2020 at 7:37 AM
NASER NASER
  • 836 POSTS
also, I doubt this has anything to do with it, has aftermarket wheels.
Mar 30, 2020 at 7:42 AM
Yeah. The wheels will not effect this because the wheel speed sensors run off a sensor to a tone wheel.
The gaping does matter but you would not use a spark plug gap tool because it is a different style gaping. You would actually use spacers/washers on the base of the sensor to increase or decrease the gap.
Here is a 1980's style video that shows this really well:
https://youtu.be/AvQlHxZuVGw
I doubt this is the issue. If you are saying there are multiple other sensors in the glove box then I suspect they tried to replace them. Again, when having these different codes I suspect there is a module issue so we need to run through that testing just to find out where the issue is.
While it could be each sensor, I have never seen all these sensors fail at the same time which is why I suspect there is a greater issue.
Mar 31, 2020 at 2:37 AM
NASER NASER
  • 836 POSTS
No there aren't any extra sensors, just couple of spark plug gap adjusters.
Mar 31, 2020 at 9:12 AM
Oh. I understand. Okay, unfortunately we will need to just run through the test to see what the issue. As I stated, I suspect you will find a possible ABS issue.
Mar 31, 2020 at 10:39 AM
NASER NASER
  • 836 POSTS
I just got a chance to drive it and live data shows rear ones showing speed while fronts are not.
Apr 20, 2020 at 3:11 AM
Interesting. It is unlikely that both would fail but it is possible especially if this vehicle is new to you. They probably did not fail at the same time. They were just never fixed.
I attached the process but I doubt you need to remove much as you should be able to see the speed sensor on the hub and remove it with just taking the tire off.
Clearly I would inspect the sensor first to make sure they are there and connected. If they are replace them and retest.
Apr 20, 2020 at 12:16 PM
