Speedometer not working and ABS light is on after replacing ABS sensor and wheel bearings?
200,000 MILES • 1.6L • V6 • 2WD • AUTOMATIC
DAN2002182020
ABS light is on and speedo doesn't work after replacing wheel bearings and ABS sensors,
Jan 16, 2021 at 7:49 AM
  • 55,711 POSTS
It sounds like the sensor is not plugged in? Can you double check our work please? Let run the codes to see what comes up, here is a video to help show you how:
https://youtu.be/rTtAnsOlZU4
and
https://youtu.be/Pb6nXV-iamI
Let us know what happens and please upload pictures or videos of the problem.
Jan 17, 2021 at 10:33 AM
