ABS light is on and speedo doesn't work after replacing wheel bearings and ABS sensors,
Jan 16, 2021 at 7:49 AM
✓Experienced Mechanic
It sounds like the sensor is not plugged in? Can you double check our work please? Let run the codes to see what comes up, here is a video to help show you how:
