ABS and advance track lights on
168,489 MILES • 3.2L • V6 • 4WD • AUTOMATIC
RYAN719
So I was driving home from work and my ABS light and advance track light came on. Then the 4x4 started to flash. When I got back in to town I shut the car off looked at the wires for the speed sensors and all looks good. I started it back up and all light when out. But I still do not have. Any suggestions?
May 30, 2018 at 11:16 AM
Good morning.
The ABS system has a fault with the light indicating on your dash. That code is stored and needs to be checked. A parts store can read it for you for free. Once we know that code, we can help narrow the area of failure for you. The most likely cause is the wheel speed sensors but that needs to be confirmed.
When the ABS is off line, the Trac and four wheel will also be off line. When the ABS system is repaired, they will come back on line.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
May 30, 2018 at 11:15 PM
RYAN719
Okay, cool. I will do that and keep you posted thanks.
May 31, 2018 at 2:03 AM
Keep us updated and feel free to ask any follow up questions.
May 31, 2018 at 3:31 AM
RYAN719
So I found out that it was the right front sensor was bad hooked up a code reader and gave me c1145 and got a new one and replaced it. Thanks again works like a champ. Sorry I took a little long to respond. Thank you again for the help.
Jun 3, 2018 at 11:52 PM
  • 55,554 POSTS
Nice work, we are here to help. Please use 2CarPros anytime.
Cheers, Ken
Jun 6, 2018 at 3:47 AM
