ABS, advtrac, lights come on. And 4×4 high blinks on and off
238,047 MILES • 0.6L • 4 CYL • 4WD • AUTOMATIC
RODNEY CALAVAZA
As i were driving. The advatrac came on and later on the ABS light came on. So we stopped, turned the car off. Then i took the battery cables off the battery terminal. Waited for awhile them hooked it back up. Started the car and it still came on. And now i checked the fuses. And when i goto drive it. It starting to make clinging noise in the front. What can i do to fix it
Jan 27, 2019 at 8:16 AM
  • 110,246 POSTS
Hi and thanks for using 2carpros,com
Based on your description, it sounds like one of the ABS sensors has failed. What you need to do is scan the computer to determine which one has failed. A bad sensor will set both of the lights you referred to. What happens is the computer sees two different speeds from the sensors. As a result, power is reduced to prevent slipping. Does the engine seem to have power loss? If so, take a look at the following links.
If you have a scanner, here is a quick video showing how to use one to retrieve codes. If the car is safe to drive, often times a parts store will scan it for free.
https://youtu.be/YV3TRZwer8k
Here is a link that discusses ABS sensors (AKA Wheel Speed Sensors).
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Here is a way to test them if you don't have a scanner.
If you determine one of the sensors has failed, here are the directions for replacing them. I will start with the front. All attached pictures correlate with these directions.
Front Wheel Speed Sensor
Removal and Installation
1. Disconnect the battery.
2. Remove the RH front rotor.
See Pic 1 and 2
3. Remove the parts in the order indicated in the following illustration and table.
4. To install, reverse the removal procedure.
____________________________________________________
Rear
Rear Wheel Speed Sensor
2. Raise and support the vehicle.
Pic 3
3. On vehicles equipped with anti-lock brake system (ABS) only, remove the parts in the order indicated in the following illustration and table.
Pic 4
4. On vehicles equipped with ABS with stability assist, remove the parts in the order indicated in the following illustration and table.
5. To install, reverse the removal procedure.
Item 1 (ABS With Stability Assist): Electrical Connector Removal Note
1. Remove the rear wheel and tire.
Item 4 (ABS Only): O-Ring Installation Note
1. Install a new O-ring.
Item 1 (ABS Only): Electrical Connector
Installation Note
1. Apply electrical grease to the connector terminals.
Jan 28, 2019 at 11:39 AM
