ABS activating when you come to a slow stop.
175,000 MILES
ED1313
  • 13 POSTS
ABS started activating at a slow stop after I replaced the front right bearings. now I have changed all 3 ABS sensors and the front right brake caliper. I checked fuses and all. what else can I try?
Nov 2, 2013 at 8:37 AM
SATURNTECH9
  • 30,868 POSTS
Does the abs light come on?you might need a scan tool that can read live abs data to see what's going on.
Nov 2, 2013 at 8:49 AM
ED1313
  • 13 POSTS
No ABS light comes on.
Nov 2, 2013 at 9:41 AM
SATURNTECH9
  • 30,868 POSTS
Your going to have to use a scan tool to watch the speed sensors to see what's happening when the abs kicks in.
Nov 2, 2013 at 11:37 AM
ED1313
  • 13 POSTS
will I get a message when this happens while scan tool is plugged in?
Nov 2, 2013 at 1:26 PM
SATURNTECH9
  • 30,868 POSTS
No you will need a advanced scan tool that can reach live about data and watch the speed sensors while someone drive and see if one of the speed sensors reads different then the rest when the abs kicks in when it shouldnt.
Nov 2, 2013 at 4:20 PM
ED1313
  • 13 POSTS
But if they are all new sensors I put on what else could it be? I was thinking I may have did something to the rotor when replaceing the bearings?
Nov 3, 2013 at 12:14 AM
SATURNTECH9
  • 30,868 POSTS
You still have rust etc that can effect the speed sensors if you can see if the speed sensors are even a problem and which sensor is having the issue.Otherwise who knows whats going on otherwise?Without a professional scan tool its all luck and guessing.
Nov 3, 2013 at 1:12 AM
ED1313
  • 13 POSTS
I changed the rotor and it fixed the problem.
Nov 6, 2013 at 10:57 AM
SATURNTECH9
  • 30,868 POSTS
So what was wrong with the rotor?
Nov 6, 2013 at 1:23 PM
ED1313
  • 13 POSTS
Have no clue the rotor looks fine. but that took care of the problem.
Nov 9, 2013 at 3:22 AM
SATURNTECH9
  • 30,868 POSTS
What made you suspect the rotor?was it the front or rear rotor?
Nov 9, 2013 at 6:17 AM
ED1313
  • 13 POSTS
It was front passenger rotor. That was the side I replaced the bearings in cause its a 2wd so the bearings are in the rotor. That was the only thing I had left to try to replace lol. I replaced all sensors, front brakes,passenger side brake caliper,and then the rotor which was the ticket so just glad I fixed it.
Nov 9, 2013 at 7:03 AM
SATURNTECH9
  • 30,868 POSTS
At least you got it glad to hear it.
Nov 9, 2013 at 7:19 AM
