ABS code 31-02 inlet solenoid malfunction.
132,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
DUYBUI66
Feb 19, 2018 at 6:21 PM
KHLOW2008
  • 41,812 POSTS
This is the trouble code for front right inlet solenoid malfunction. As the component is within the modulator unit, there are no service parts and has to be replaced as a complete unit. What you need to do is to check the wiring first.
Apr 9, 2021 at 6:13 AM
DUYBUI66
can I replace modulator unit, I mean whole unit and where are they located? As far as I know they might located under dash board passenger side. Please advice.
