Where is the ABS system fuse located?
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
KEVO57
Dec 22, 2023 at 2:01 AM
  • 55,694 POSTS
There are four fuses that run the system fuse# 11 in the fuse panel at the left side of the dash controls the ABS warning light. Fuse #6 100 amp located in the fuse panel at the right rear of the engine compartment is the main ABS pump motor fuse, and the fuse #115, and #109 in the fuse panel at the right side of the engine compartment control the ABS module. Check out the images (below). Let us know if you need anything else.
Dec 22, 2023 at 5:05 AM
