ABS is being displayed on the dashboard and it is preventing the speedometer from working?
2005 TOYOTA AVENSIS
666 MILES
ABIMBOLAISRAEL
ABS is being displayed on the dashboard causing the speedometer to not work.
Dec 1, 2023 at 2:54 PM
  • 110,240 POSTS
The speedo and ABS light are likely related to the same thing, a wheel speed sensor. Have you scanned to computer to see if there are any codes stored? If you have, could you let me know the codes that were found?
Also, take a look through this link and let me know if it helps:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
joe
Dec 1, 2023 at 3:09 PM
